Easy Show Compatibility
finer500
Post by finer500 » Tue Mar 29, 2011 1:02 pm
I am new to this forum as well as the sunlite suite so bare with me. I have been using the software to program a light show synced with music, as you are all aware, easy show is perfect for this but there's a problem. The first class controller is out of my budget for the show which means I won't be able to use easy show with my fixtures, correct? (I'm assuming that the cheeper controls just won't respond when attempting to use easy show.)
If this is a fact, does anyone know of anyways around this, possible using easy time or something like that to sync with music? As of now, I can't seem to find any practical solution that is cost effective.
Again, pardon my ignorant question, and thanks in advance.
Re: Easy Show Compatibility
Post by simonB » Wed Mar 30, 2011 9:16 am
If you try to use EasyShow without an FC connected it will not work.
You could:
-get a Suite2 BC or Suite2 EC
-play your music on a device that outputs Midi Time Code(if you dont have one then get some software which does and get a virtual midi cable software package)
-link the midi timecode to a cycle timeline
