Master dimmer -> work not in exported Cycles
dstar
Post by dstar » Sun Sep 05, 2010 11:33 pm
my next problem
I have some Events with RGB Spots and Moving Lights with additional Master-Dimmer Curves.
After Export the Show to master_cycle, the dimmers will not work. 90% of all Events comes full on/off.
No smooth dimming are possible.
With EasyShow is the Output to the Lights correct.
Any Solutions?
Christian
Re: Master dimmer -> work not in exported Cycles
Post by simonB » Mon Sep 06, 2010 7:05 pm
Hi Christian
I'm not 100% sure what you are referring to here.
Do you mean that if you insert a scene into easy show and modify the dimmer within easy show, it does not work properly?
dstar
Post by dstar » Mon Sep 06, 2010 8:18 pm
I have some macros (for example: blu light, red light etc.) in the Timeline.
In Easyshow, i make dimmer-curves for this macros.
If i play the show with Easyshow, the dimmers are work.
But after export to cycle, i have no effekt.
But, i think i see the problem.
The cycle is only a List and plays the original macro without the additional Easyshow curves.
Christian
thestereo
Post by thestereo » Mon Feb 17, 2014 9:27 pm
I have the same problem
you've decided your own?
