i'm having a problem where i set easyshows sync to midi, chose my device (MOTU Micro Express). All works fine while in the session, I save the show and re-open and Syncro is still set so MIDI, but no devices appear in the dropdown list until I click the reset button, then I have to chose my device again.
This is a fairly big problem for my installation.
Cheers for looking.
Sync source lost after saving and re-opening show
Re: Sync source lost after saving and re-opening show
Hi
Which version are you using? A modification was made regarding the MIDI time code about 1 month ago. This has either fixed or created the problem. If your version is over 1 month old, try the latest beta and see if it is fixed.
Hi Simon,
It is still there in the beta.
Sorry for the late reply, I missed your post. Yes I see this is still a problem. I have already spoken to the developers regarding this and was told that it had been fixed. If it is still causing you trouble, it may be better to contact dylan. You can find his e-mail address by selecting his name (he is one of the moderators). Contacting him directly should speed up the process in getting the bug fixed.
