Stick KE1 color changes turns on all lights
abergus
Post by abergus » Fri Dec 30, 2016 1:12 pm
Hoping you can help.....
I have two KE1's and I programme them with ESA pro.
my problem is this.
Whilst programming the controller if I create a scene using a selection of my rgb lights in the esa pro standalone tab I can select the color slider and then change the colours of those lights on the fly.
Once I write the sticks memory and use it in standalone mode if I call the same scene and then change the color slider it will turn all the rgb lights on and change them to the selected colour.
I would like it to work the same way as it does when controlled by the software,is this possible?
Many Thanks and Happy New Year,
Alex
Re: Stick KE1 color changes turns on all lights
Post by nick » Wed Feb 08, 2017 4:06 pm
Hi Alex,
Thank you for the question.
Unfortunately it is not possible to change the color of an effect on the fly in standalone mode. It is only possible to override a scene with a static color. I will make a suggestion to see if this is possible in future products.
