STICK-KE1 Lights All Flash
Patchkno
Post by Patchkno » Thu Oct 13, 2016 10:29 pm
Have a unit that is 1 year old. Has worked wonderfully up until this week.
When powered up all seems well until you activate a scene. I have only one programmed, so activating #1 acts as normal for about 30 seconds, and then it fails and ALL lights on the STICK-KE1 flash on and off over and over again.
When hooked via USB to PC, all is fine.
Any help is appreciated!
I note in manual that it should have a 6v adapter but has a 9v.
Not sure if this is a problem................
Re: STICK-KE1 Lights All Flash
Post by nick » Wed Oct 19, 2016 1:55 pm
Hi Patchkno,
Thank you for your message.
Can you please submit a support request using the following link and we will be able to resolve this for you:
https://store.nicolaudie.com/repair
KathrynTriak
STICK KE1 Lights All Flash
Post by KathrynTriak » Thu May 31, 2018 4:01 am
I have a stick gu2 controlling my leds. Everything was ok but now 1 light is a different color from the rest.
Also when I turn the lights off 1 fixture stays on.
Any help?
Thanks,
Chris
https://www.1prikid.ru/ Могу я купить кошельки женские мaгaзины москвы
