Tools access
mbolan
Tools access
Post by mbolan » Thu Sep 24, 2015 2:45 pm
Do I need to access the tools utility to setup anything for the calendar or sunset position/location? I'm using a STICK-KE1 firmware1.19 SN26549. When I try to open the hardware manager that loaded with ESA PRO it does not see any USB connected device even though the stick is connected and connects to the ESA PRO program.
Ben
Re: Tools access
Post by Ben » Wed Oct 14, 2015 12:33 pm
Hi there,
The HardwareManger is where you set-up the Location and Timezone along with the Sunrise Sunset Calculator, this is needed if you want to use the Sunset/Sunrise triggers on the device.
Did you still have ESA Pro opened and connected to your device when you tried to connect to the HardwareManager? You will need to close ESA Pro for the device to be detected in HardwareManager and vice versa.
Also please make sure you are using the latest version of the software/HM found here: http://www.nicolaudie.com/downloads/fil ... robeta.exe
Hope that helps.
