Hello
My KE-1 works 2 years in restaurant. But this Friday I had such issue.
When I switch on the controller and press 1 key on A page everything is fine. But when I trying to change page from A to B all LEDs on controller starting blinking several times, then they blinking one by another and after that controller acting like it had been just turned on. I pressing 1 key then press arrow to change page and everything repeats.
I know for sure that the pages B,C,D are signed on this controller.
And one more thing. Some times it happens that I managed to switch pages from A to D without restarting. But when I switch page from D to E (E page is not signed on this controller) all this mess repeats (the LED indicators are blinking and all fixtures fall to blackout).
Can you help me?
All LED on controller blinking when chenching page A,B,C,D,E
Re: All LED on controller blinking when chenching page A,B,C
I changed AC adapter and now everything works fine
AC adapter to KE1 is 9V 0.65A. But I was surprised when found out that DE-3 has 6V power supply. I thought that power supply should be same for whole range of STICK. But it's not so.
Anyway now everything is ok
The same 6V power supply works for all STICKs except the KU1 which requires 9 volts. The KE1 works fine with 6V.
