low level flicker with firmware update
Posted: Tue Apr 22, 2014 3:30 am
Stick KU1 Firmware 1.19 Device Firmware Compilation date 2014-01-28 08:43:08
Just installed windows 7 64 bit. Had been using 7 32bit prior. Downloaded and installed latest Esa Pro package and also hardware manager. After drivers installed, Hardware manager indicated a firmware upgrade. The installed was 1.19 with no compilation date and the current was also 1.19 but with a date. I upgraded successfully. Launched ESA Pro and downloaded the programming from the STICK device to make one small change in my program calendar. wrote back to the device. One of my scenes is a static blue to eight different fixtures used as a VERY dim nightlight in our ceilings cove. The fixed values I use vary between fixtures from 004 to 005. This used to present a very low continuous light level. If I run the scene from within ESA Pro editor, it still presents a very low continuous light, but when I disconnect and run the program from the STICK by itself, I now have what appears to be about the same very low light level but with a very fast but prominent and annoying flicker. Did not have this with earlier firmware. Any ideas? I also observed a timed calendar event now starting way late. I checked the time and date to be correct as well as DST. I re-re-synced the clocks, checked settings and will see what happens tomorrow. Can firmware be reverted if needed?
