Original STICK Audio Response changed with latest firmware
bigdarkspot
Post by bigdarkspot » Sun Dec 01, 2013 8:52 am
I hadn't changed the firmware on my employer's STICK for quite some time, but had to upgrade when I added some more lights that weren't correctly supported with the older version of ESA Pro I was originally using. The new one supports the fixtures fine (Technobeams), but the audio responsiveness has changed, especially for fades. It seems if you do a fade, or a shape using the shape generator, when you turn audio on (by hitting Select 7) it moves a fraction of the fade each beat rather than considering the whole block a 'beat' like it used to.
Any plans to change this back? it makes the audio response useless with moving lights.
Jeff
Re: Original STICK Audio Response changed with latest firmwa
Post by simonB » Thu Jan 02, 2014 2:53 pm
Hi Jeff, can you remember which version it worked in? I wasn't aware that the pan/tilt effect ever worked with audio
