send blackout trigger for calender
stsetrep
Post by stsetrep » Thu Nov 14, 2013 8:38 pm
Hi, i would like to put the stick into standby/blackout at dawn everyday, i can easily set a scene but cant see how to set standby? i want to use the relay trigger port hence the reason for standby i think? unless the black out function works if you set 0 dmx value?
Also the explanation of blackout trigger is very vague? i can only assume that on black out stage pin 12 goes to zero and triggers the relay? what triggers pin 12 to go zero pressing standby or setting a zero dmx value on all dmx channels?
Is there a comprehensive manual?
many thanks
Steve
