Calendar 40 Trigger limit
KevinG
Post by KevinG » Tue Nov 12, 2013 4:16 am
I am trying to setup the calendar with ESA PRO to trigger several scenes on different dates but I get blocked from entering a date range after the first coupe of scenes and then when I try to write to the stick it reports that there is a limit of 40 calendar triggers and it has removed the extra triggers. I don't see any calendar trigger limits on any STICK KE1 specs. I also confirmed that the clock and date are correct in the Stick. Firmware 1.19 serial 20830.
Could something be wrong in the parameter settings in the hardware tools?
Do you have detailed instructions for all the parameter settings?
Any advise would be much appreciated.
Re: Calendar 40 Trigger limit
Post by simonB » Thu Nov 14, 2013 3:52 pm
The 40 calendar trigger limit can be found here in the comparison chart:
http://www.nicolaudie.com/en/stick-range.htm
Maybe you can group your triggers, for example have a single trigegr which runs on a certain day of the week, date of the month or every day between 2 days
KevinG
Post by KevinG » Wed Nov 20, 2013 4:00 am
Thank You Simon.
More calendar event Triggers would be a useful upgrade for me .
