STICK-KE1 DMX Channel not enough
achung1
Post by achung1 » Wed Aug 07, 2013 2:22 am
Dear Mr.,
The STICK-KE1 DMX Channel was insufficient for our needs. We will need 2992 Channel and stand alone operation for outdoor show .
Could you assist how I extend the STICK-KE1 DMX Channel via ESA Pro ?
Best Regards,
Albert Chen
Re: STICK-KE1 DMX Channel not enough
Post by simonB » Thu Aug 08, 2013 11:12 am
Hi Albert
The KU1 supports a maximum of 1024 channels. It's possible to synchronise KE1's over a network, however the maximum channel count across all KE1's is always 1024. To access 2992 channels, you'll need to use 3 SLESA-UE7's connected to a router or switch.
achung1
Post by achung1 » Fri Aug 09, 2013 1:27 am
Dear Mr.,
I still have some question, please kindly advise.
1.After I set 3 SLESA-UE7 scene via ESA pro, SLESA-UE7 still connect the computer via Ethernet ?
2.All of 2992 channels can apply for individual control ?
Best Regards,
Albert Chen
Post by simonB » Fri Aug 09, 2013 11:16 am
Hi Albert
This will work in stand alone (in fact it doesn't work in LIVE yet). You can set one of the UE7's as a master and the others as slaves.
Yes, all 2992 channels can be controlled independently with this method.
This is a brand new feature which requires a new beta version of ESAPro and a new firmware which we will be putting up next week.
