KU1 DMX out issue
tracyu
KU1 DMX out issue
Post by tracyu » Tue Feb 19, 2013 10:10 pm
I have a KU1. I'm trying to test the DMX output with my miniDMXter4 test device. however whenever I activate scene's I see no DMX output from the unit. I have also tried using the Tools application text tab and don't see anything on the output. My cables are wired correctly. I am able to connect to the unit with my USB cable. It appears to read and write to the data card.
Another question, Can I use the tools test tab to verify the DMX address of the fixtures I'm attempting to control?
Thanks!
Re: KU1 DMX out issue
Post by simonB » Fri Feb 22, 2013 2:07 pm
Hello
It's not possible to check the address number of the fixture because our interfaces are not RDM compatible, only DMX. I suggest to patch 512 single channel fixtures in ESA Pro and set them all to 100%. If you still have no output, it could be a problem with your DMX chip. An easy way to check this is to swap the 2 DMX chips. More information on where the chips are located can be found in the STICK datasheet
