can i use the RS232 output on the stick KE1 to projector
MichelleLam
Post by MichelleLam » Tue Nov 20, 2012 1:05 pm
Hi! I just got my stick KE1. I want to use it to control the shuttle on/ off and the audio on/off from my stick. The projector model is Sanyo PDG-DHT8000L. Can I just use the RS232 from the stick and connect to the RS232 input at the projector? or Do I need to add a RS232-DMX converter?
Re: can i use the RS232 output on the stick KE1 to projector
Post by simonB » Tue Nov 20, 2012 2:13 pm
The RS232 socket on the STICK is an input, therefore you cannot control another device via RS232. The only output is DMX therefore you would require a DMX-RS232 converter. As these devices are quite rare they are not so cheap:
http://www.dfd.com/232.html
MichelleLam
Post by MichelleLam » Thu Nov 22, 2012 5:20 am
Thanks! I found a company who can modify RS232 to DMX but I still cannot get a hold with Sanyo to get the RS232 coding for that model of projector. :(
