Control with audio
Lightemore
Control with audio
Post by Lightemore » Mon Oct 08, 2012 1:09 pm
Good morning,
I need to know if you can do with KU1 of scene changes or step controlled by the external audio equipment, such as using a microphone or audio input dedicated
Thank you, goodbye
Re: Control with audio
Post by simonB » Thu Oct 11, 2012 4:53 pm
It is possible to jump between steps with an audio input connected to the KU1 or by using the KU1's input microphone. Hold select+7 to enable/disable audio
Note that:
-this is not compatible with the KE1
-the sensitivity is adjusted automatically
-this can only be enabled globally
-it is not possible to enable this from an external command except with a UDP message through ethernet
