STICK rs-232 protocol
tony32
Post by tony32 » Fri Aug 17, 2012 12:02 pm
Hi, I found out the tx & rx on the stick for long time ago and connect it to the computer serial port with successfull result.
Only problem is that the stick hangs and I have to disconnect the usb power cabel several times a day only when I have the serial port attached. Even if no commands are sent.
Then I found this video and you have probably connect it on same way?
Should I try to use a max232 between stick and computer serial port, maybe different levels crash the stick?
Re: STICK rs-232 protocol
Post by simonB » Tue Aug 28, 2012 2:50 pm
There is no need to use max232. You need a standard RS232 input level.
It's hard to say if this is a hardware or software problem. The best solution is to try with another STICK. Mail me your serial number and I'll arrange to have it swapped over.
