Disable Standby / power off
Enlightened
Post by Enlightened » Wed Aug 08, 2012 1:14 pm
We are just installing a pair of Sticks in a church. They are networked together, with one synchronised with the other.
Is it possible to disable the standby button? The problem is that if the unit with the dmx coming out is put into standby, the second controller has no effect or, way to turn it back on! I can see some confused people trying to make the lights come on when the primary unit has been put into standby. We have used sceen 8 on every page to be the 'black out' / lights off state, so the standby is really not wanted.
All ideas welcome, the quicker the better. We are currently on site programming at the end of an install.
cheers
andrew
Re: Disable Standby / power off
Post by simonB » Mon Aug 13, 2012 12:04 pm
Hi Andrew
It is possible to synchronise the blackout over ethernet. This option can be found on the Ethernet tab of the tools.exe.
It is also possible to disable the blackout on the Parameters tab of tools.exe.
Tools.exe can be found in the software directory and windows start menu
