Stick ESA Pro saved files can't open
Posted: Mon Jun 25, 2012 5:38 am
Hi
I am looking for some ways to sort the following issue out
I have the following Issues with a Stick and the ESA Pro software package
I have windows 7 64 bit laptop running ESA Pro version (April 30 2010) with this I have created and uploaded files to the Stick
However I need to use a different computer with the latest version of ESA Pro and this is where the problems have started, when i try to open the .arc files with the most recent version Of ESA Pro ( May 21 2012) I get the following error message
"Unexpected file format."
and it refuses to load the file
Also when trying to access the STICK it refuses unless I update the firmware on the Stick
If I update the stick will i be able to down load the files from it, or do I need to reprogram it ? how would I resend the program if I can't open it in the latest version OF ESA Pro ???
As I have more than one file I wish to be able to load I can't seem to transfer them via the stick if it will not work on the older version of ESA pro after the firmware update
any ideas or workarounds ?
Dave
Dave
