Calendar dosent work
ALIASpl
Post by ALIASpl » Sat Mar 17, 2012 6:24 pm
Hello I haw install two STICK 1 KU1 - witch com+, latest firmware and latest EPA PRO,
Program is work correct, bat calendar no.
I make everything on instruction, when i make save the calendar in not turn on any program why?
Re: Calendar dosent work
Post by simonB » Fri Mar 30, 2012 2:45 pm
Open Hardware Configuration- Tools.exe found in the software directory and windows start menu. Check that the clock is set correctly.
If it is, send me your show and I'll test it.
