Problem with LED-Stripes
Helmar
Post by Helmar » Fri Nov 11, 2011 9:22 am
I try to controll three LED-stripes via DMX. I use the Stick KU1 with Com ( Software version 1.18). When i controll the stripes via pc and software, everythings as it should, but when i use the panel or my smartphone, the following happens:
I controll only one stripe per scene, normally it should be white, but when I change the color, all three stripes begin to shine, althought they have diffrent adresses. When i want to switch back on white, all three stripes shine white.
When I switch between the scenes, the old ( changed ) parameters are still there, so i have no chance to reset to the saved scenes.
Re: Problem with LED-Stripes
Post by simonB » Mon Nov 14, 2011 4:56 pm
Hello
I dont understand your problem.
-When you are speaking about changing the color, do you mean by moving the color fader or by activating a scene?
-Do the scene triggers work as expected?
-What result are you expecting?
Helmar
Post by Helmar » Tue Nov 15, 2011 7:03 am
When I activate the scene, the selected stripe have the right color, but when I move the color fader all three stripes begin to shine and the only way to turn them off is to switch off the power.
Moreover, it would be good if a stored scene could be called again,by pressing the button again . At the moment I change my stored scenes every time, when i use a fader.
I expect that saved scenes can not change and the LED strips are to be controlled individually.
Post by simonB » Tue Nov 15, 2011 9:05 am
If all three strips are in the same zone, then that's correct because the color fader overrides all lights in the zone
Double tapping a scene resets any dimmer/speed/color modifications
It is always running in the background, double tap to reset the fader modifications
Helmar
Post by Helmar » Tue Nov 15, 2011 9:40 am
Ok, now i know what to do. Many thanks!
