my STICK doesn't turn on
pablo
Post by pablo » Fri Oct 22, 2010 4:36 pm
when i plug my STICK to the 9v adapter it doesn't turn on
instead when I conect it to the usb port it works normally
when i look in to the rma sheet i talks about problems in the fuse
how can i fix it?
thanks
Otherwise i'm not very shure about the problem is in the fuse...
Pablo
http://www.pablomartinezdiez.com/
Re: my STICK doesn't turn on
Post by simonB » Fri Oct 29, 2010 3:01 pm
It sounds as though there is a problem with the power.
A few things to try:
1. make sure you have the switch pointing to ext
2. make sure the + and - are the correct way round
3. Try a different adapter
If you still have no power, send me an e-mail with your serial number and I will set you up a returns
