connect 2 s.t.i.c.k. together
markon
Post by markon » Tue Apr 20, 2010 5:37 pm
How we can connect 2 stick together. We want use 1 stick in the begining hall and second in the end of the hall.
I need information about the connection intermidiatly
We try to put rs232 communication between stick, with tx and rx with reverse function
Re: connect 2 s.t.i.c.k. together
Post by simonB » Wed Apr 21, 2010 8:21 am
A Master/Slave option is not possible, but may be at some point in the future.
For now, the only option is to use ethernet. Put the same program on both STICK's, connect both STICK's to a router (you will need the ethernet add-on). You will also be able to control both STICKs from a remote control application available for PC, MAC, Linux, Iphone, Android Phone and Windows phone (as long as they are connected to the network).
Kovalev
Post by Kovalev » Thu Sep 02, 2010 9:39 am
Hi Simon!
Is this function work now?
How can I connect 2 stick's via rs232 ?
Post by simonB » Thu Sep 02, 2010 9:46 am
The STICK only receives RS232. You will need an RS232 device to send signals to both STICK's. We are still working on master/slave functionality, but this will all be implemented through ethernet.
