STICK Audio Input
SimonE
STICK Audio Input
Post by SimonE »
I have recently installed a STICK controller and all is working successfully. I now want to connect an audio input from an A/V receiver to enable sounds triggering. This has a standard L/R audio output that I think I can use.
There are no real details of how to connect up an audio input on your data sheet - could you clarify:
(1) Which Pin connections are the audio input on the extension socket connector
(2)Can I connect straight up from the A/V receiver - or is there anything I need to take care of ?
(3) I have used ESA Pro to create all of my scenes - and this has worked vey well. Could you tell me how I enable audio triggering ?
Re: STICK Audio Input
Hi
Audio is still not ready, this should be sorted before the end of the month.
Kovalev
Post by Kovalev »
Hi Simon! So is audio input work now?
Do you have scheme?
Hi, yes audio input works, see the STICK audio tutorial at www.nicolaudie.com/nicolaudietv
