STICK - RS232
LIGHTfaktor
STICK - RS232
Post by LIGHTfaktor »
Can you please provide an example of an RS-232 trigger command for the STICK controller. I followed the instruction for connecting the RS-232 as shown in the tutorial video. However I don't get a response from the STICK when I send a command. I am not sure what could be wrong. Maybe my string is formatted wrong (ie. maybe I need comas or no spaces between the bytes). So just to be sure that I am not doing something wrong; Can you give me the actual string that I would need to use to trigger preset 1 to play? (note: in my show the trigger on preset 1 to address 1)
Thank You,
Wes Lane
Re: STICK - RS232
Make sure you are sending hexadecimal values and not ASCII.
Ox01 Ox01 OxFF
no comers or spaces
tony32
Re: STICK - RS232
Post by tony32 »
Hi, I have it working with messagetype
01 Play
02 Stop
03 Pause
04 Resume
05 Reset. No effect on reset? What does it do?
I can only start the first 8 Scene's from scripting, I have 40 active Scenes on Stick.
SendToComPort(comport, Chr(&H1) & Chr(&H8) & Chr(&HFF))
Have tried to loop the seond byte from 01 to FF but only the first 8 scenes are responding.
Any suggestions?
Thanks.
ShelbyVis
Re: STICK - RS232
Post by ShelbyVis »
Has anyone tried this with a Crestron control system?
I have the baud set to 9600, 8, None, 2.
I'm sending \x01\x01\xFF out of my com port. I know my pin out is correct. I get no response and the scene does trigger.
Any help would be greatly appreciated.
