Version 2014 with Freestyler > Gobo Rotation issue
kittmaster
Post by kittmaster »
Using the latest version that Freestyler downloads from the site, my known good versions that use the 2012 version (haven't updated my production system) works as expected with my ADJ X-Move LED 25R with gobo rotation in visualization.
The 2014 update on a test system now shows no gobo rotation at all. Every other feature of the light visualization works correctly except gobo rotation.
The DMX levels show Freestyler sending the right data between the programs for the channel gobo rotation on that channel.
Not sure what to do next, can anyone comment if they are seeing the same thing?
Thank you
Chris
Superbaloo8
Re: Version 2014 with Freestyler > Gobo Rotation issue
Post by Superbaloo8 »
Instead of using "Rotation" on prism canal (SSL2), use a prism, where you will set the "rotation property".
And then in 3D it will works :)
  • Interface Economy Class
LightJockey
  • @MixLightEvent (31) France
