FPS speed / graphics
Posted: Mon Jun 08, 2015 8:16 pm
Hi all
maby many poeple allready ask this but i could not find it.
but i'm getting a realy low FPS its allways at 21
if i turn resolution low its still at 21.
if i turn it to Maximum its 21.
but the point is when i enable Shadows the software goes all over the place.
when i change DMX values it drops to 8FPS
its not the biggest problem to run without shadows.
but what type of pc do you need to run this?
it uses more then Crysis 1 and witcher 1 and these are demanding games.
specs:
Mobo: corshair V formula-z
Cpu : AMD-6100 (default 3.1ghz x 6, current 4.0ghz x 6)
Ram : 2x 4Gb @ 2100 mhz
Videocard : 1x Nvidia 770 GTX 4Gb @ 1080mhz (gigibyte vesion)
freestyler as DMXSoftware.
greetz, Spirit
specs:
greetz, Spirit
