Custom objects editor
ArnHue
Post by ArnHue » Thu Nov 01, 2012 1:05 am
Is there any documentation how the custom objects editor works? I'm almost desperate because of it! - I'm trying to create a easystrech projection cloth. It consists of 30 points and when I placed these points loosely for the first time, an object could have been buit. Then I moved some of these points to more precise coordinates... and the editor showed the error message "could not build this oject". When I move some of these points back, an object can be created again - perhaps!
What's the problem? It seems to be just a matter of luck if it works or doesn't.
ArnHue
Re: Custom objects editor
Post by ArnHue » Thu Nov 01, 2012 11:05 am
By the way, I'm using Magic 3D easy View Beta from 27 Aug 2012. I've tried with the regular release form 21 May 2012 as well. But here the custom objects editor seems not to work...
ArnHue
Post by ArnHue » Thu Nov 01, 2012 12:15 pm
O.K. apparently the custom objects editor just doesn't like symmetry. When I shape the object a little bit asymmetrical - it works! Too bad that designes often plan symmetric stages... ;)
Post by simonB » Wed Nov 07, 2012 5:18 pm
you need to make sure that the lines aren't getting crossed. If they are not and you sitll have the error, send em a screenshot of what you're trying to draw
