the best pc hardware
raystream
Post by raystream » Sun Apr 15, 2012 12:58 pm
hi
what hardware (cpu, graphic card) is recommended for easy view.
i would like a min. of 20fps for advanced rendering in high or max settings with enabled shadows.
RayStream - Media
http://www.raystream.de
Re: the best pc hardware
Post by simonB » Wed Apr 25, 2012 11:30 am
With the latest EasyView, the DMX recording and rendering are made in separate steps. This produces a smooth playback even with an older processor or graphics card.
Basically the faster the processor and the more grapahics memory..the faster the real-time visualisation will be.
raystream
Post by raystream » Wed Apr 25, 2012 4:57 pm
i know faster cpu and better graphics card will give better performance
but my question was which cpu and graphic card are for a normal/little stage?
normal/little stage:
4-6x moving head
2x acls bars
4x sunstrip
4x led rgb bar
12-20x par64
1xstrobe
6-8x fresnel spot
i know when i want to visualize more lights i need more power.
which hardware setup would you recommend for visualizing this stage?
RayStream - Media
Post by simonB » Wed May 16, 2012 5:07 pm
It all depends on the amount of object's you're using. If you want to visualise those fixtures in real time with movements, a stag, a few musicians and some truss. An NVIDIA GeForce GT 330M 512 MB would be the minimum spec you'd need.
