Unable to see rotation of gobos in the vizualizer
stonehedge
Post by stonehedge »
Im unable to see any rotating gobos in my 3d visualizer. Any ideas what i muust do please ?
Regards
raystream
Re: Unable to see rotation of gobos in the vizualizer
Post by raystream »
need a little bit more info:
version of easy view,
fixtures you use and want to see the rotating gobos,
maybe it will be the best if you post your easy view stage file.
RayStream - Media
http://www.raystream.de
raystream
Post by raystream »
without the requested infos nobody can help you.
RayStream - Media
Fisherman
Post by Fisherman »
stonehedge wrote: Im unable to see any rotating gobos in my 3d visualizer.
Regards
Hey everyone,
I've got the same problem. The Version is V1.0.3.5 (Jan 27 2012).
Marcel
raystream
Post by raystream »
i am using the same version with different fixtures without problems.
which fixture are you using?
RayStream - Media
stonehedge
Easy View 2006 is what im using. Simon sent me an email saying the rotate preset must be double clicked on. Then the window that opens you should select link to channel and select the gobo channel from the drop down list. This enables gobo rotation in the visualizer.
stonehedge
But im still unable to correct my gobo shake channel. No matter how i create the preset it still shakes in the opposite direction. I mean the dimmer when i raise the dimmer to 100% it shakes slow and when i slide the dimmer to 0% it shakes fast. I tried correcting it and now when i just import the light into a page its already just shaking on its own even without the GOBO SHAKE even being active.
Fisherman
Post by Fisherman »
Hey,
I tried this but nothing happened. I think my fixture is programmed right. The gobos are set as "rotating gobos" and the presets of the rotation channel are set to the gobo channel.
Is there something I didn't think of?
Another question: What is "Ombres"? You find this at "options".
Marcel
raystream
Post by raystream »
ombres are shadows.
i think this is spanish somebody forgot to translate it.
RayStream - Media
There is a problem with this menu, some items ar ein the wrong order. This will be fixed in the next beta
