Easy view 3D Sep 28
gabrielefx
Easy view 3D Sep 28
Post by gabrielefx » Sat Oct 15, 2011 10:20 pm
Dear Sirs,
the Movie recorder doesn't work for me.
I try to save an avi file and I get an empty video, all frames are white.
Any help?
Re: Easy view 3D Sep 28
Post by simonB » Mon Oct 17, 2011 12:45 pm
Hi, we are working on this problem, we will have a new version available this week
l2net
Post by l2net » Fri Dec 09, 2011 12:39 pm
there are problems when you play strobe work. The rate of bursts does not change linearly. The only problem is the screen itself the unit runs properly. thank you
Post by simonB » Tue Dec 13, 2011 8:18 am
Does this happen when advanced rendering is disabled?
Check that the strobe property is set correctly in the fixture profile. You can set a minimum and maximum speed here and set linear or random.
Thomasjueliversen
Post by Thomasjueliversen » Thu Apr 11, 2013 2:55 pm
How do i create a fixture in the scanlibrary. Editor ?
I need to make a 7 Channel Par 64 Led.
Can anyone explain,
Best wishes
Thomas
Post by simonB » Mon May 20, 2013 6:52 pm
