LED RGB color bar stripe just displays red colour
Posted: Wed May 26, 2010 11:02 pm
by atista
I am using the Lightmaxx LED RGB Color Bar Stripe. My main problem is, that it just displays red colors. Beside this, it seems that it does not work in 6 channel mode (channel 1 set to a value between 16 and 31). Any idea what is wrong?
Re: LED RGB color bar stripe just displays red colour
Posted: Fri May 28, 2010 9:22 am
There are a few issues I have noticed here:
1. The profile is badly made. Either fix it yourself or request that we make one for you, you can find info on this here:http://www.nicolaudie.com/main.php?id_page=32
2. Fixture profiles cannot dynamically switch between different modes. I suggest you choose the most preferable mode and stick to this
3. I'm not sure which software you are using with the fixture, but only Sunlite Suite 2 fully supports multi-beam fixtures. You will have to manually control each channel with any of the other software packages
4. The visualiser cannot visualise multi beam yet, you will find that the whole object will illuminiate. This is something for future development
