atomic
riverboatG
atomic
Post by riverboatG » Thu Oct 08, 2009 2:15 pm
hey people
can i use the blinder effect of Martin Atomic 3000 in offline?
best regards
Re: atomic
Post by simonB » Fri Oct 09, 2009 8:49 am
Hi, I'm guessing you're using channel 1 mode here. The effect can be achieved by creating a shutter open preset. I have created a profile for 1 channel mode, see ATOMIC 3000 - M1 in the online the SSL library
riverboatG
Re: atomic
Post by riverboatG » Fri Oct 09, 2009 7:34 pm
how can i go to ss library? is diferent !
Re: atomic
Post by simonB » Mon Oct 12, 2009 2:18 pm
From now on, the procedure to request a SSL file for your new lights has changed. If the fixture you are looking at is missing in the library, you will have to log into our online store logme to browse the online library. Then if the particular fixture is not available, select "Fixture library request" from the SSL Libraries section and follow the instructions.
It is also possible to upload your own profiles to our server for other users.
Note: you will have to create a new account if you are not registered already.
