Object Placement Problem
sborder
Post by sborder »
Hi, sometimes when I put an object in a stage and set it precisely (typing in exact numbers and not using the up-down buttons) then save it, and reopen it the object has moved and is out of line with another object.
I use the feet feature (not metric) for precise placement of objects such as, textures for keyboards, textures for tvs, light placement, wall placement, and other things.
Here are several examples
File Download
Thank you.
Samuel
sborder
Correct Picts
Post by sborder »
Hi, Here is what the models should look like.
Samuel
Marc
Post by Marc »
We are going to see what happened. May be not enough precision when saving objects positions...
We will fix it in the next version.
thanks for playing...
