Gobos Look Bad
techie159
Gobos Look Bad
Post by techie159 »
When i use gobos in the 3d view it just shows up as the gobo in a way. but all the beams from the light muddle up the pi and it looks rubbish and nothing like the real thing is there a way to turn the beams off without loosing the spot or gobo on the surface its on
This is How they Are! ( the Gobo its ment to be is at the side)
Image :(
This is how they shoud be and are in other software!
Image :lol:
Post by bruno.falip »
Options -> Rendering mode -> Advanced
techie159
Post by techie159 »
bruno.falip wrote:Options -> Rendering mode -> Advanced
What about if it says ur pc's grafics is not powerfull a nough the othere software that i used to use can manage it with a same spec pc so why carnt this!
Marc
Post by Marc »
Maybe the other softwares don't use the same technology.
We are using DirectX for the 3D, they may use OpenGL...
With our visualizer, you can't have advanced rendering with
your Graphic Card...
thanks for playing...
