Workflow small night club
DJGStefan
Post by DJGStefan »
I would like to have some advice with the setup/work-flow on the Sunlite program. I'm working as a DJ in a new opend night club in Lebanon and I have never worked with any kind of light before just with good light-jockyes.
The light rig is really small, two moving head washers, 4 moving heads, and 8 fixed washers. I also control most the ambient light in the club, witch is RGB lead strips. It is all installed and it all works well. I have programmed some scenes that works ok, but now I want to dig deeper and make something very good. I have a Akai MPD24 MIDI controller that I use for switching between different scenes. The MPD24 have 8 faders and 8 knobs that I will try to programe as well, to stuff like speed dimmer.
So far, I have just done Master scenes. Which makes it easy for me to switch all the lightning at the same time, but I have less control.
Can anyone give me any suggestion what to think about when I do the programming?
I understand it's a big question, but I have no experience at all so I would be happy for any input I can get.
