Help with 3D on sunlite suite 1
alvdrums
Post by alvdrums »
Having problems getting my lights to do the same patterns or movements as what the 3D is doing. In the construction mode listing I have clicked on the Fixture then using the down Blue arrow I have tried to change the "invert Pan & Tilt" to match everything up. Once I have that done I then text that they are match up. For my text I get the lights to go forward and back and side to side and everything seem to be working ok. Then when i get the light to do a figure of 8 or another pattern this is when the lights and 3D goes out of Sync. Can someone please tell me how to sort this problem out.
Re: Help with 3D on sunlite suite 1
Open ScanLibrary and open your fixture profile. Check that the minimum and maximum pan and tilt degrees match the ones written in your manual
alvdrums
Post by alvdrums »
Thanks Simon, That sorted it for me .
Allan
