Copy button not working
gerardopellicer
Post by gerardopellicer »
Hi. My problem is when I try to copy a button to a new fixture, it stops working, the programmed data is lost. I also tried to copy the entire fixture, and then changing the dmx channels but no luck, the programmed buttons are lost. Help!
Gerardo
Re: Copy button not working
Post by bruno.falip »
It is not possible to copy a button to different DMX addresses.
gerardopellicer
Ok. If I am working with, let's say, two PAR64 LED, and I want them to do exactly the same colors and effects, but I want to control them apart, for example, switching on one first and then the other. Do I have to program each light effect and color one by one, or there is a way of using the same buttons, by grouping or something?
Gerardo
Yes, you must use the group function. It is explained in the user manual.
gerardopellicer
I read the manual, but I can`t understand. Could you explain, please?
Gerardo
