Some bugs, and proposals
Geerinckx
Post by Geerinckx »
hi there,
Controlling group function:
The group function stil doesn't work with midi command, how come?
for example, i have 2 color buttons linkt to 2 midi buttons, the first turns 2 heads bleu, the second turns them yellow!
when i link a group with only the first head to a button, i puch thad and than the new color i turns the 2 heads in the color instead of only the group thad i have selected with the midi command!
control speed, size of all movements:
when i link multipel speed and size functions from movement scene's to 2 midi faders i get a lot of delay and my cpu speeds up to 100%!!
for example, i have 3 midi buttons and 2 midi faders, i links teh first button to "Center" the second to "Polygone" en the tirth to "circle"
The first pot to the speed fader of the "circle" en the speed fader of the "Polygone" movement!
The second pot to the size fader of the "circle" en the size fader of the "Polygone" movement!
But now whene i turn the pot i get al lot of delay, and it is verry cpu hungry!
Whene i link more speed ans size faders to the pot the delay gets bigger and bigger!
Speed faders range isn't large enough:
Whene you create a page, you can adjust the speed of the movements in 4 different ranges
Is it possible to enlarge the range, so when i move the speed fader to the left the movement stands stil and to the right its goes verry fast!
Happy newyear greetings from Belgium
Gert Geerinckx
dylan
Re: Some bugs, and proposals
Post by dylan »
I take all in consideration, I do my best to fixed all.
For the speed range I can't modify this, perhaps in the next version of Sunlite !!!
Happy new year.
------- Dylan --------
dylan
Post by dylan »
I made some modifications to optimise the midi.
You can download this zip file that contain an exe of Sunlite, just unzip this file in your Sunlite directory.
www.dmxsoft.com/global/beta/Sl2006.zip
Geerinckx
Post by Geerinckx »
Thx for the reply Dylan,
I test the beta version ASAP
Greetings
Gert
playboy
Post by playboy »
Whis this Update work the SL 2048 EC not, its not found in the Soft. SL 512 EC /FC are ok.
dylan
Post by dylan »
My new exe must be copied in a nov 4 version of sunlite !!!
