more boxes linked with usb to 1 pc
robymilani
Post by robymilani » Sat Mar 27, 2010 2:45 am
hi guys..
i have to run 6 dmx universe using sunlite...
can i use new suite2fc box with old sunlite suite 1 software??
can i use 2 sunlite suite2FC at the same time,on the same pc, so i can have 3+3=6 real universe?
i ask you this, because other solution is to buy 6 SUNLITE SUITE FC+ (the old ethernet one) link on a switch... but i think it's more expensive then the upper solution... is it??! can you confirm?
Re: more boxes linked with usb to 1 pc
Post by simonB » Mon Mar 29, 2010 9:29 am
You can use 2x suite2FC interfaces to achieve 6 universes of output in Suite 2, but in Suite 1 you can only achieve 4 DMX output universes and 2 DMX input universes. This is because a lot of data structure changes have been made in the 3DMX universe interfaces.
