I am a mobile DJ, so I often will be setting my lighting up at different locations and in different formats.
I think it would be great if there were some means to restrict movement of some of the scenes.
For example. I would like some of the scenes to allow for the full movement of the moving head (perhaps for lighting a doorway or doing some patterns on the walls), and others to restrict them just to the dance floor.
I would like to be able to go in (much like the settings for a fixture page) and create a restricted area for the movement, and then apply that to ONLY a few select buttons. So, perhaps in the button settings there could be a "Apply movement constraints" check box or something like that.
Then, at my next event, I would just modify that restricted area for the new location, and it would then apply to those buttons.
I hope this makes sense!?
Feature Request
- SuperMaxi Forumor
I think the feature to add here would be to pick a focus point and have an effect (ie circle) center around that point instaed of always starting from center. In other lighting consoles, you can apply the fx algorithms to a position preset and the fx would be centered around that x,y position. It would be nice for Sunlite to do this as well. That way you can limit your fx to a certain spot.
