Scenes edit
angelo85
Scenes edit
Post by angelo85 »
Goodmorning I've bought the Sunlite Suite and now I use it for a Musical. So, I'd like to make the scene before the show.
So I'd like to know if I make the switch with the position of the moving head and I use these switches for some scenes, if I edit the switch also the scenes will edit, like the palette that are in a lot of console.
Angelo
Poldi
Post by Poldi »
So, basically you are asking: if you include a switch in a scene and decide to edit the switch afterwards, will the scene which was created using that switch change accordingly?
as far as i know - i'm pretty sure: it does not. the memory of a scene will not be affected in any way if you are messing around with switches as long as you do not store any new commands into that scene.
greetings,
jan
