Probs in 3-D Viewer
playboy
Probs in 3-D Viewer
Post by playboy »
I have Robe Colorspot 1200 AT. In reality works perfekt, but not in the Viewer(Mode 1 and 2 its the same Effekt)
The CMY-Macro, Gobo Index 1 and 2 (Rotation), XY-Macro and XY Macro-Speed works not in the Visualisation. In reality work it. It this a Bug ?
Post by bruno.falip »
Gobo Index and rotation should work. If not, then the profile is not correct. For the rest, there is no possibility to show a macro...
playboy
Post by playboy »
Thanks for replay and Information that Macro is not to see, but the Goborotation is not to see. The Gobo is ok, but it not in rotation/shake in visual.
The Profile must by ok. the realwork on Colorspot is ok are not in Viewer?
riverboatG
Re: Probs in 3-D Viewer
Post by riverboatG »
i have a smilar problem
so
all of 1200At's always runs on 3D on frost !
what is this ? a bug?
teggers
Post by teggers »
[quote="riverboatG"]i have a smilar problem
so
what is this ? a bug?[/quote]
There is an actual "Frost" tick (check) box in the visualizer under construction mode under fixtures. It is the little round circle next to the paint bucket. I use it to diffuse a par beam from spot to flood. Maybe you have that box "tick"ed by accident for your fixtures. It is immediate when you tick it, so should see it right away.
We have updated these profiles, they will be online soon.
