Adding Fixtures
Schadow63
Adding Fixtures
Post by Schadow63 »
I added 2 Accu Spot 250 II's to a page that already had 2 AS250II's. None of the pre-programmed buttons are working on the 2 new ones. I clicked on regenerate pre-programmed buttons but it only patched the movement buttons and none of the others. Is there a better way to add fixtures to an existing page so all the buttons will work.
Also, I made some changes to the pre-programmed buttons to function how I wanted them too. Is there a way to save them so when I regenerate the buttons it doesn't change the settings I made?
switch
Post by switch »
I am having the same problem.
You got no reply so i will bump it.
Post by bruno.falip »
Unfortunately not. Sorry for that.
