External i/o connector
The stand alone Ethernet interface.
jharris
Post by jharris » Wed Jun 21, 2006 3:34 pm
Hi Hope you can help!
I need more info on the external I/O port. Im using a PLC running relays to switch between scenes. It works fine when only 1 port is triggered. However when you trigger multiple ports, to get a binary number, the unit gets confused. Im sending a 5 second long burst of the correct port address.
How does the SLESA know when multiple ports are connected not to look at them as indvidual triggers? What happens with switch bounce? How close must mutiple port addresses arrive together to be counted as one binary number.
Best regards
Jon Harris
adam1976
Yes!
Post by adam1976 » Mon Jan 01, 2007 4:28 pm
I couldnt ask that question any better. Any help on this will be a big help. We are having the same problem!!!.
julien
Post by julien » Tue Jan 02, 2007 8:44 am
The processor checks every 80ms the state of the I/O port.
You don't need a burst.
