SELSA IP1 Power ON-OFF Function
The stand alone Ethernet interface.
AntanasDam
Post by AntanasDam » Tue Aug 04, 2015 1:50 pm
Hi, I have problem with SELSA IP1.
I am programming everything, writing to memory, going to “Stand Alone mode” – everything works fine, but if I am disconnecting item from power, and connecting power back – the system do not go to "Stand Alone" mode, green LED do not blinking and device do not starting from first program – if I want to go to "Stand Alone" mode I need to connect computer and to start “Easy Stand Alone” program.
I am using SELSA IP1 to control lighting, and the lighting is controlled by RELAY, so every time the system is going Power OFF and Power ON.
What can be a problem???
Thanks.
Ben
Re: SELSA IP1 Power ON-OFF Function
Post by Ben » Fri Aug 07, 2015 8:53 am
Hi there,
Please can you make sure the device is updated to the latest version of the firmware? For this device the firmware needs to be updated within the Easy Stand Alone software.
Check that and let us know if you're still having problems.
