Streaming DMX Recording Capability
The stand alone Ethernet interface.
Lighting1
Post by Lighting1 » Tue Oct 12, 2010 4:51 pm
Is it possible to record a DMX data stream to any of the interfaces? If so, which units have this capability and where is this functionality accessed as I don't see it in the software? Also, what are the time or file size limitations? Any issues? Thanks for any info you can provide. I am working with a company interested in buying several of these if they can properly play back recorded DMX data streams. Thanks.
Re: Streaming DMX Recording Capability
Post by simonB » Wed Oct 13, 2010 5:13 pm
Hello
There are 2 ways to go about recording DMX.
1. use tools.exe (found in the software root directory) then write directly to the SD card or interface
2. use the record function is easy stand alone to take a snapshot of the incoming DMX
You will need a SLESA-U7 or STICK for option 1.
You can use any interface in the architectural & building range for option 2.
As the interfaces use SD memory there are almost no memory limitations.
