Master in stand alone
The stand alone Ethernet interface.
ferrod68
Post by ferrod68 » Wed Mar 04, 2009 11:24 am
I would like to work with three IP and i saw that in the configuration exist Master in stand alon and slave in stand alone. What do I do to use it?
bruno.falip
Re: Master in stand alone
Post by bruno.falip » Wed Mar 04, 2009 1:22 pm
Using several interfaces to control more DMX universes
It is possible to link several interfaces on the same local network in order to create a multiple universes stand alone show. It is important to set the master and slave units. The master interface is used to trigger the whole system. By default. the master unit is the one with the lowest IP address.
Each ethernet interface is shipped with the same IP address (192.168.1.20) If you are using more than one ethernet DMX interface, you must connect the interfaces one at a time and change the interface IP address within Easy Stand Alone (explained in the Hardware manual).
