How to 'Take' a scan and move it again
stuartuk
Post by stuartuk »
One problem I find when doing corporate shows is that I want to make small adjustments to a head position. I might press and hold down q or w and move a head -works fine. Then they move the set and I need to move it again. If I press q or w again, the Switch goes off and the head goes back to preset and I have to start all over again. Can I change it so I can move each head by pressing q or w again each time or selecting it with the mouse without resetting position? Also is it possible to adjust mouse movement resolution for more subtle control? Am I missing something obvious?
Thanks in anticipation, Stuart Roberts.
webguyinternet
Post by webguyinternet »
I am not a developer but I see some obvious problems with what you want. When you use the "Take" command you are actually just mapping the XY cordinates of your mouse on the screen with the XY coordinates of your fixture. The only way I can see that working is if they save the mouse screen position (and lock the mouse button down) and snap it back to that exact previous location when you issued the second take command. I'm not sure if Windows allows this?
I too have had this problem but maybe it could be a simple implementation for the final release of 2006 software.
stuartuk
Post by stuartuk »
Thanks for your input Lance. I am hoping it can be implemented in 2006 final release. I assume its' a matter of the switch remembering the previous X/Y positions - hopefully!
Stuart
Guest
Post by Guest »
This is a new feature of the 2006 sofware. If you press "Alt+Take button" the fixture moves to the previous recorded position and you can modify it.
