big problem can you help me
giancarlo
Post by giancarlo »
id like to know if this is a bug!
ive made a real big stage with everything including pa stuff and dimmer stuff ecc so im using a lot of textured obgect now when i try to modify an obgect and then i put a texture in it it seems to save it but it doesnt load it after what is this?
Marc
Post by Marc »
If you change the texture on an object, the software should copy the picture file in the folder of the object. Check you have the (bmp or jpg)file you want apply on the object with the X file. Be carreful of recording the changes you made.
thanks for playing...
