Is it possible to patch static lights together ?
Haytech
Post by Haytech »
I bought a DMX In Interface and I wonder how it is
possible to patch static lights together like we do in live situations
with backtruss light´s...
Is there a software tool to start videos or other media via DMX in ?
´Thanks in advance
Sebastian
Marc
Post by Marc »
Can you give us more informations as what's the software you're using!! (Magic, ESA, Sunlite...).
thanks for playing...
Haytech
Post by Haytech »
I use the Magic 3D Vis tool
regards
Marc
Post by Marc »
when you add new fixtures, check the "multi fixtures" option to patch them together.
There is no way to start video via DMX IN.
Haytech
Post by Haytech »
EDIT:
I checked it bit it isn´t active on any fixtures I selected
what is to do to use the multi fixtures option ?
2nd qustion
Is there any aplication planed to start media via DMX-IN ?
Any solution would be very good - and would gain the use of DMX IN.
TIA
regards
Haytech
Post by Haytech »
I wonder why no one is answering on my post to Apr.18.2005...
Guest
Post by Guest »
1- You must select an existing fixture from the list to add multiple fixtures to the same DMX address.
2- This is possible with Sunlite 2004, you can create a switch to start your media and then trigger this switch with a DMX IN channel.
Haytech
Post by Haytech »
Salut! Bruno Falip
many thanks this works good for me !
Your software is a very helpful tool
regards
Sebastian
